X Axis Sizes
kevin.w18
(@kevin-w18)
X Axis Sizes
Hi there,
a few weeks ago, I broke the plastiC on the left side of my X Axis. Tighten the screw too much, shame on me.
it's named "X-end-motor" in the manual.
https://d17kynu4zpq5hy.cloudfront.net/igi/prusa3d/qT444MbWrAxURST3.medium
the blue arrow.
I fixed it with glue and printed a spare part of it. The spare part looked perfectly fine and I switched it.
But it seems the holes for the metal parts are a bit too small. I can put the steel tubes in(but need alot of force), but I think the X Axis is a bit too large, I can't position the printer head the Z Axis all the way down. As far as I screw it down, I have to use more and more force.
So I want to fix that problem with a drilling machine. I think I just need the enlarge it 1-2mm and it will work perfectly fine.
Which ends up with my question. What are the exact sizes of the X axis.
- What's the diameter of the holes? What's the deep?
- How much of the steel tube should look out of the plastic? What's the whole length of the x axis?
And at least. Should it be a problem to enlarge it for 1-2mm? I think it shouldn't be a problem, but I just want to ask.
Best regards
Kevin, the guy, who tighten too much
Veröffentlicht : 12/10/2018 10:38 am
Re: X Axis Sizes
Hi Kevin,
can you point to the particular holes on the picture, and show a picture off the assembled printer showing the problem?
1 - 2 mm seems a lot to be drilling out!
Veröffentlicht : 12/10/2018 1:50 pm
kevin.w18
(@kevin-w18)
Re: X Axis Sizes
https://imgur.com/CytO3hj
My paint skills are horrible but I think you can see what I mean.
I already dismantled the printer, so I can't show a picture. I can make a picture of the printed part at the evening, but as far as I see there isn't a problem.
I just want to expand this two holes a bit so I can push the two rods a bit further in. I think that will solve my problem.
The problem is, if I move the x Axis down to the bed, to more I move it down the more resistance I got from the Z-axis screws.
Because the screws are a bit loosen on the top and fix on the bottom, the problem seems to be the width of the x-Axis.
That's the reason I asked for the correct width of the whole axis, so I can compare it with mine.
Or in other words:
9. Preflight check
Step two doesn't work, the resistance on the screw is too large.
https://manual.prusa3d.com/Guide/9.+Preflight+check/514?lang=en#s8292
https://d17kynu4zpq5hy.cloudfront.net/igi/prusa3d/VjdibZsN3O4TsaTl.medium
Veröffentlicht : 12/10/2018 2:04 pm
bozzo
(@bozzo)
Re: X Axis Sizes
Kevin,
the X ends should have little square ports at the bottom of the holes so that you can visually inspect that the smooth rods are bottomed out in their holes.
I had a similar issue with reprinted parts (but I saw they did not seat properly) and I forced them together with a (padded) wodwoorking clamp 🙂
Not looking forward to next disassembly...
Veröffentlicht : 12/10/2018 4:06 pm
Kai
 Kai
(@kai-2)
Re: X Axis Sizes
@bozo
If you use a heatgun it is pretty easy to remove tight seated rods from the ends.
Just make sure that you don´t heat it up to much, otherwise your rods and ends will be "glued" together.
nec aspera terrent
Veröffentlicht : 12/10/2018 4:41 pm
kevin.w18
(@kevin-w18)
Re: X Axis Sizes
Hi there,
I used some abrasive paper and a screwdriver to enlarge the holes. It worked perfectly fine and I could push the rods in alot easier. A
A drilling machine would be to much probably, I just needed about 1/10mm maybe less.
The tip with the square points was great, I already forgot about them.
Thanks for the help.
I used some oil, a hairdryer and a tong to remove them. Just be aware to not damage the rods with the tong. I used some old clothing material for it.
Veröffentlicht : 17/10/2018 8:18 am
