X-Axis Motor Stutter
I am having issues with my recent build of a MK3. I have noticed that when print a diagonal the layers would shift every so often and I wasn't sure what was happening. I looked closely at the movement and noticed that the X axis motor has a stutter every few seconds.
I checked that the motor was tight and the belt does not appear to be loose.
I uploaded a couple videos to hopefully get some insight.
Any help is appeciated.
Re: X-Axis Motor Stutter
Good on you for posting a video, you're seeing the pulley slip on the shaft of the motor...that dot makes it quite obvious, it should stay in sync with the pulley.
Make sure one of the grub screws on that pulley is on the flat side of the shaft of the X-motor, and make sure they are well fixed.
That should do it!
