X Axis motor and belt adjustment query
Andrew
(@andrew-5)
Hi
I have built my Mk3s and could not get the motor pulley/belt to run without the belt scraping on the orange housing. The gap between the pulley and motor is <0.5mm.
Even if the pulley touches the motor the belt still hits the plastic. I have resorted to fitting washers to move the motor back.  Anybody else had to do this?        View of beltView of spacers
Best Answer by Neophyl:
You have the pulley on back to front.  The 'thin'  rim section should be towards the motor.
https://help.prusa3d.com/en/guide/3-x-axis-assembly_27464    Step 9 ;Note the warning about the orientation in Red
Opublikowany : 14/05/2020 11:21 am
RE: X Axis motor and belt adjustment query
Opublikowany : 14/05/2020 11:54 am
Andrew
(@andrew-5)
Thank you 👍 . Can't believe I missed that. Will sort it when it stops printing .......in about 2hrs.... 🤣 🤣
Opublikowany : 14/05/2020 1:30 pm
