X Axis length error on self test
My i3 Mk3S has been running flawlessly for the past 6 months since I built it (apart from an occasional MinTemp error on switch on reported elsewhere)
Last night a print crashed with a terrible birds nest. This has never happened before.
Now it keeps reporting an X axis length error
I tried the recalibration wizard but get the same error
Selftest error:
Please check :
Axis Length
Axis.  X
Has anyone any idea what could be wrong? How does it measure the X axis length as there are no limit switches?
RE: X Axis length error on self test
Dont know why this posted twice. I diont think It's anything I did. I cant see how to delete one of the posts
Have you considered to reset to factory values and then run the printer through an initial setup?
Cheers
Chris
@just3d
Isn't that what happens when you run the setup wizard? It certainly warns you that everything will be reset.
@just3d
