X-axis length error on recalibration
EclecticGamer
(@eclecticgamer)
My printer has been running smoothly for years but I recently started to have what appeared to be leveling issues. When I tried to rerun the calibration, it fails on the x-axis length test.
I'm trying to adjust the belt tension to see if that's the issue but I wasn't sure what else could be going on.
Opublikowany : 30/12/2022 5:47 pm
It could be an obstruction, including an obstruction to the cable bundle; a clogged or failing idler bearing; dirty or unlubricated smooth rods; or mistensioned belts.
Opublikowany : 30/12/2022 11:30 pm
