X-axis layer shift in first 5mm
I recently moved my mk3 into an Ikea Lack enclosure, and have started getting persistent layer shifts. For example, I tried to print the 60deg heatbed cable cover 3 times and got the same shift each time. The first layer looks good, but the next 5 or so layers are each offset laterally by a couple of mm left to right. Once it gets past about that first 1mm or so the shift stops and the rest of the print is fine. However, for a part that needs through-holes the surface is ruined.
My belt status shows X tension at 235 and Y tension at 278. Is my X-belt too tight? What else should I be looking at?
Firmware: 3.11.0-4955
EINSy_10a
E3Dv6full
Date: Apr 7 2022
RE: X-axis layer shift in first 5mm
hi, for helping other user to help you, may you post a picture of the defected print on the bed? 😊
I'm not an expert. Ma parlo anche italiano 😉
Instead of belt tension check the grub screws that attach the pulleys to the motor shafts. Small offsets are usually a sign that they are no longer tight and were not installed properly. If you don't tighten in a specific way then they work loose over time.
Loosening the X belt seemed to help. I have it down to 263 now and was able to print a couple of parts with no layer shifting. I'll also take a look at the grub screws, but I'm pretty sure I got those installed correctly the first time. Thanks for the ideas.
