X-axis idler buzzing sound
Semkan
(@semkan)
Hey there!
I’ve been printing with my Prusa MK3 for weeks now. It just came to my attention that when printer makes rapid x movement, I hear some buzzing sound coming from x-end idler area. Do you think it is overthingtened? Or maybe some other cause? It seems that it doesnt effect the print quality but certainly it is irritating a little bit.
Opublikowany : 04/07/2018 1:59 pm
Re: X-axis idler buzzing sound
on my Mk1 Prusa Original i3, the X Idler bearing self destructed. before it's final collapse, it made odd noises...
If this is happening consider getting an aftermarket Idler with twin ball races.
have you tried a couple of drops of oil on the sides of the idler wheel? (Easiest test)
and or loosening the X idler Mounting bolt a turn (next easiest test)
Opublikowany : 04/07/2018 4:32 pm
