X-Axis Belt Clicks when moving.
Pebble
(@pebble)
Hello,
When my nozzle move along the X-Axis there is a clicking noise. Also I noticed that the belt rotation thing on the right is moving quite a bit. The belt looks like bacon as well, but I am not sure if it has always looked like that or if it is rust. I have a video the problems as well. Please help me out.
Videos ↓↓↓↓ (I do not know why but it downloads the videos when you click on them. Sorry for the inconvenience.)
Clicking sound
Rotation wheel moving
Bacon belt
Thanks,
Postato : 30/11/2022 2:24 am
It looks like your X axis idler bearing has failed.  To check, loosen the belt and try turning the pulley by hand (fingertip) - is it smooth?
Also check the thin part of the X end idler; if the nylock was pulled in too tight it can cause extra wear and collapse the part.  You may need a torch and a dental mirror to be certain.  If uncertain print the replacement part *before* disassembly.
Postato : 30/11/2022 5:21 am
RE: X-Axis Belt Clicks when moving.
My X axis idler collapsed and I replaced it with a twin bearing idler roller.
Never had a problem since fitting the replacement
Postato : 30/11/2022 9:23 am
