X-Axis Belt Clicks when moving.
Hello,
When my nozzle move along the X-Axis there is a clicking noise. Also I noticed that the belt rotation thing on the right is moving quite a bit. The belt looks like bacon as well, but I am not sure if it has always looked like that or if it is rust. I have a video the problems as well. Please help me out.
Videos ↓↓↓↓ (I do not know why but it downloads the videos when you click on them. Sorry for the inconvenience.)
Thanks,
It looks like your X axis idler bearing has failed. To check, loosen the belt and try turning the pulley by hand (fingertip) - is it smooth?
Also check the thin part of the X end idler; if the nylock was pulled in too tight it can cause extra wear and collapse the part. You may need a torch and a dental mirror to be certain. If uncertain print the replacement part *before* disassembly.
RE: X-Axis Belt Clicks when moving.
My X axis idler collapsed and I replaced it with a twin bearing idler roller.
Never had a problem since fitting the replacement
