X axes interference
master moccasin
(@master-moccasin)
X axes interference
I had to replace the X axes bearing assembly and now I get an X axes error. It appears the bundle of wires running down next to the fan are hitting the vertical bearing assemblies. Not enough travel. I may have down loaded the wrong replacement part? I have the i3 from several years back.
MM
This topic was modified 4 years ago by master moccasin
Posted : 24/02/2022 6:59 pm
RE: X axes interference
It looks like you have printed a NON Original Prusa part.
I believe what you have was a Mk3 printer, if this is correct, the part you need is called
x-carriage.stl
At the following URL
https://www.prusaprinters.org/prints/88240-i3-mk3-printable-parts/files
Posted : 24/02/2022 8:56 pm
master moccasin
(@master-moccasin)
Hi Joan,
I knew it was different but appeared to be simpler to install. Must have been for a different model or printer I did down load the proper one and will be installing it today.
Thanks,
George
Posted : 25/02/2022 11:03 am
Good luck George.
For information, the Fan and Motor wires are supposed to go in slots in the Prusa extruder prints, held in place with the Extruder Cooling Fan! (Left Hand Fan.)
Posted : 25/02/2022 9:41 pm
