Wrong X homing after power failure recovery
I have 4 Mk3S but just in one of them, if the printer looses power suply by not controlled reasons (local Company supply), the restar fails after wrong X homing. It looks like it slams the x axis too strong on the x axis, so strong that home on x gets missplaced by 0.5 or 1(mm) . On pictures attached you can see the slight shifting on perimeter and infill. This repetitive issue just makes the power auto recovery useless.
Why could this be happening?
Thanks for all your help.
Postato : 09/10/2022 6:42 am
RE: Wrong X homing after power failure recovery
I would think you have a mechanical issue with your X Axis. Have you looked at the location of the grub screw on the motor?
Postato : 10/10/2022 11:55 pm
