RE: Wrong Nozzle Temp
If you are reading 288°C, on the 100K thermistor table, that would make the resistance approximately 125.7ohms. It should be 120k ohms, but if you use the wrong type of thermistor, like the PT100, which has about 125 ohms at room temp, I think you did not buy the correct thermistor. You need the 100K NTC thermistor.
Publié : 06/04/2021 4:01 am
