wrong hotend LCD temp reading
Saz
 Saz
(@saz)
after changing the thermistor and the heater cartridge the LCD temp reading is maxing around 188C when I preheat the hotend to 215C
according to an infrared temperature gun the cartridge gets to about 255C
why is the mismatch and how to fix it?
Respondido : 12/01/2021 9:41 pm
RE: wrong hotend LCD temp reading
Hi Saz,
is the thermistor a genuine Semitec 100Kohm cartridge thermistor?
does it read the correct temperature at rest? (Room temperature? )
is it securely fitted in the heat block?
Respondido : 13/01/2021 2:18 am
Saz
 Saz
(@saz)
it started when I purchased and replaced the hotend with a new genuine E3D V6 hotend.
the temp max at 188, then contacted E3D excellent support people, and now I m awaiting a replacement.
I contacted Prusa live chat, again top notch support, they guys are sending a replacement as the printer is under warranty.
whilst I m waiting, I tired a 3rd party hotend from Amazon. but the exact same thing is happening, temp reading max at 188
all connections are secure, resistance reading seems normal
I wonder, is something wrong with the board?
Also, would the 16-18C ambient temp have an effect?
thanks
S4
Respondido : 13/01/2021 8:07 am
Miembro
@saz
That sounds like the board since you are getting multiple hotends and thermistors with the same reading.
Respondido : 13/01/2021 12:07 pm
Saz
 Saz
(@saz)
yes, I m suspecting the board.
not sure how to prove it?
Respondido : 13/01/2021 12:14 pm
