Wipe Tower not showing up
shad0wman37
(@shad0wman37)
Hello,
I don't know if this is the right location to post but it seemed like the best I could find.
I'm currently using a printer called Klic-N-Print 3D and wanted to use Slic3r Prusa Edition to help with oozing problems when using both my extruders. However, even though I enabled the wipe tower it doesn't show up in the preview or gcode.
Publié : 08/07/2019 10:09 pm
Dave Avery
(@dave-avery)
RE: Wipe Tower not showing up
i suspect you need to define the printer to have 2 extruders.
Publié : 08/07/2019 10:21 pm
shad0wman37
(@shad0wman37)
Posted by: david.a66
In the Printer settings? if yes, then it is
Publié : 08/07/2019 10:36 pm
shad0wman37
(@shad0wman37)
When I click "Single Extruder Multi Material" the tower shows up, but when I try to slice it says that the tower can only be created via Marlin Gcode. My printer uses Sailfish, is there any Sailfish wipe tower version?
Publié : 10/07/2019 12:10 am
LePe
 LePe
(@lepe)
Membre
Apparently there are several reasons why WipeTower can hide itself.
After studing all possiple help files and struggling about an hour and comparing all possiple settings,
I finaly found thet Wipe Tower do not show up because I had changed printing layerheight from 0,20 mm to 0,25 mm.
So if you have a problem with Wipe Tower check printing layer height setting please.
I believe that it's safest if it's sometking what PRUSA has set it's original Print Setting profiles.
Happy Printing with the MMU.
Publié : 01/04/2024 10:41 am
