Where to buy repacement screws
Penetal
(@penetal)
The screw for the filiment extruder I have is half loose and the treads for the tool have come somewhat undone.
Where can I get the tiny little screw that holds the filement feeder gear in place? Or the propper specs to buy the correct one myself?
Opublikowany : 20/08/2018 5:52 pm
Peter L
(@peter-l)
Re: Where to buy repacement screws
According to the assembly manual there's supposed to be a spare lockscrew in the package. Did you save your spare parts?
Opublikowany : 20/08/2018 6:04 pm
Frio
 Frio
(@frio)
Peter beat me to it. I know the kit came with a spare setscrew, not sure about pre-assembled. Either way according to Bondtech it is an M3 setscrew. Seems to me it was smaller based on memory (not able to verify at the moment) but Bondtech says it is M3 so it must be an M3.
http://shop.bondtech.se/en/drivegears/drivegear-kit-175-direct.html
Opublikowany : 20/08/2018 6:13 pm
Penetal
(@penetal)
I had the same problem with both, do you think I could buy this instead? 1/5th the price http://shop.bondtech.se/en/spareparts/shaft-assembly-bmg.html
Opublikowany : 20/08/2018 6:44 pm
M3x2 very short
Regards Joan
Opublikowany : 20/08/2018 6:45 pm
