when im trying to print, the priner crash!
hotam
(@hotam)
hello, we bought the prusa like one or two month ago.
when im doing a pre heat to the hot end and the bed. all is warming up nicely.
but when im trying to print , the  board is restarting!
y Is that?
Respondido : 09/01/2020 12:24 pm
JustMe3D
(@justme3d)
RE: when im trying to print, the priner crash!
Did you update the printer firmware? If the problem persists nevertheless, I'd re-format the SD Card after saving the content and would use a new set of files downloaded from Prusa's website.
Respondido : 09/01/2020 2:21 pm
hotam
(@hotam)
updating the firmwere seems to work
Respondido : 12/01/2020 1:45 pm
hotam
(@hotam)
ok, time has passed
the problem keep coming back!
I formatted the SD card, Changed the SD card, Updated the Firmware
and still, once in a while I come back, and see the printer stuck in the middle of the print with the hot end on the print with the temp on!!!!!! luckily a fire never started!!!!
in addition , when I try to print again through the SD , after turning off the power for the night (the printer), when I try to print, the machine is doing a reset , its randomly. sometimes it happn and sometime it don't!!!
please help me, im frustrated
Respondido : 24/02/2020 2:58 pm
Have you contacted support via the online chat? Log into the estore using the account you used to purchase the printer and go through it with them.
Respondido : 24/02/2020 5:07 pm
Peter M
(@peter-m)
Look in the forum on how to reset the settings in the printer.
After that you have a printer like it is new, so you need to do xyz calibration.
Respondido : 24/02/2020 9:49 pm
