Weird sounds when extruder is moving along X axis
Maros
(@maros)
Hi guys.
Our 3D printer makes weird noises when printing. Printer started doing it recently, not from the beginning, so I checked every screw and I thightened them but the sound persist. Don't know what could cause it? Here is the video, in video I manually changes position of extruder so that is the sound in the backgroud, but in the foreground it makes sometimes that click sound.
Printer is MK3S
Posted : 10/12/2021 5:38 pm
This sound is only heard on X axis moves when not extruding?
You centred the image on the motor side, are you sure the sound comes from here?
I suspect the X axis idler bearing but I cannot rule out a linear bearing from the video, listen very carefully; where exactly is the sound coming from?
Posted : 11/12/2021 3:05 am
