Weird noise in edges
Hello,
does anyone know what could be causing this noise?
Opublikowany : 08/01/2024 12:52 pm
Lightly rest your finger on the corner of the print sheet - does this stop/reduce the noise?
If so check the Y carriage bearing clips (or U bolts on older models), they should be snug, not loose but not overtight either.
Opublikowany : 09/01/2024 12:29 am
