Visual Method Cube, Layer 2
I have a Wanhao D6 printer using the Prusa slicer V 2.3.3. After leveling the bed twice I am trying to print the Visual Test Object. Every time I try to print it layer two and subsequent layers look like this. I'm using 4mm nozzle with Hatchbox PLA. I have selected the .20mm quality universal print setting. I've measured the filament and calculated the extrusion multiplier. First layer is .36 and subsequent layer heights are .33 Where am I going wrong?
Opublikowany : 10/12/2021 2:04 pm
