Visible layer lines
I get lines in my prints that are much more visible then the rest. This is a new issue to arise. I’ve swapped filaments and it didn’t fix the issue, changed the tip as well. The layers are “smushed” on certain parts at the same point on each print. Different parts have different spots where it happens but when it happens it repeats in the same spot on the same parts. When I print a tube it’s on the outter surface and inner so it isn’t a layer shift but as if the z axis isn’t moving up each time as it should? I’ve tried different layer hights and it didnt change any thing I’ve also tried changing the amount of lines on the walls and it didn’t change the quality either I am at a loss at what the issue is.
This topic was modified 5 years ago by Geakster
Posted : 24/11/2020 4:14 am
Topic starter
answered:
RE: Visible layer lines
Here is 2nd photo with no flash.
Posted : 24/11/2020 4:29 am
