Very interesting problem today !
Jon Enriquez
(@jon-enriquez)
Hello ,   I', working on a Mk3s printer , so I purchased this printer back in may , its the newest printer I have working in my shop and its been flawless ever since I assembled it , the filament sensor started getting buggy so I switched off and just manually fed the material into it ,   Fast foward to this last weekend , I didnt need to use it so I decided to see if I could fix the sensor problem , I found out all it needed was to be shimmed so now the sensor works perfectly .
I set it up to print a part for me today and got the new material in and the G code loaded up and started print ,    At first it didn't want to level , So I reset it and restarted the print this time it went right through the leveling process without a hitch and began building the model , I did notice that the print was about 25mm over to the right from center but it was printing just fine so I didnt worry about it ,    At just about 75% complete I hear the print crash and the extruder homming ,   Then it went all the way over to the right and started printing again where it left off .
I stopped the print and decided to reset and restart the print to see what it would do ??     Now the printer wont home itself , it tried to start the leveling procedure from where ever the extruder is sitting at ,,   I decided to recalibrate the printer , it seems like the whole X axis shifted to the right , If I try to move axis using the settings it will move right until it stops then you can hear it trying to force itself if you keep moving the axis , when you go left it stops right at center and wont go any further , I can manually move the extruder although difficult to the home position then go and move axis with the controls all the way back and forth but it still wont calibrate home ???
I have no idea where to go next ??     This just suddenly came up , I've never had anything like this happen with these printers before ?
Postato : 17/12/2020 12:31 am
RE: Very interesting problem today !
Did you lubricate the linear bearings when you built the printer?
did you overtighten the back of the X carriage?
for may have friction preventing proper homing.
https://help.prusa3d.com/en/article/i3-printers-regular-maintenance_2072#rods-and-bearings
Postato : 17/12/2020 3:35 am
Jon Enriquez
(@jon-enriquez)
@joantabb
Thank you Joan ,     Very late last night I was thinking about the issue and I remembered on Sunday that I removed the back of the extruder then realized I didn't need to take that part off so I reinstalled the screws and tightened them down ,,    And YES I did have the screws too tight and it was creating allot more drag on the 2 guide rods and triggering the crash detection .
I recalibrated the printer this morning and everything checks out perfectly lol .
Postato : 17/12/2020 7:35 pm
Excellent news
Postato : 17/12/2020 7:40 pm
1 persone hanno apprezzato
