Very high frequency noise when the extruder moves.
refunded
(@refunded)
IMG_2433
This sound is coming out of the extruder moving. It's too high to tell where is comes from. I'd like to know why this happens, so I can get rid of this noise and a headache.
This topic was modified 5 years temu by refunded
Opublikowany : 20/08/2020 4:52 pm
Xayoz
(@xayoz)
RE: Very high frequency noise when the extruder moves.
you need to grease your bearings
Opublikowany : 20/08/2020 5:56 pm
refunded
(@refunded)
I've use machine oil on x,y,z rods. Is this caused by not greasing bearings instead of rods?
Opublikowany : 21/08/2020 10:37 am
refunded
(@refunded)
The noise happens when I move extrude x axis. I couldn't tell whether it's from rod or bearing though.
Opublikowany : 21/08/2020 10:39 am
refunded
(@refunded)
Which bearing are you talking about? Is it on the left side of the printer or bearings in the extruder motor?
Opublikowany : 21/08/2020 10:45 am
refunded
(@refunded)
IMG_2435
This is after using machine oil on both x axis rods.
Opublikowany : 21/08/2020 11:57 am
