Very high frequency noise when the extruder moves.
This sound is coming out of the extruder moving. It's too high to tell where is comes from. I'd like to know why this happens, so I can get rid of this noise and a headache.
This topic was modified 6 years temu by refunded
Opublikowany : 20/08/2020 4:52 pm
RE: Very high frequency noise when the extruder moves.
you need to grease your bearings
Opublikowany : 20/08/2020 5:56 pm
Topic starter
answered:
I've use machine oil on x,y,z rods. Is this caused by not greasing bearings instead of rods?
Opublikowany : 21/08/2020 10:37 am
Topic starter
answered:
The noise happens when I move extrude x axis. I couldn't tell whether it's from rod or bearing though.
Opublikowany : 21/08/2020 10:39 am
Topic starter
answered:
Which bearing are you talking about? Is it on the left side of the printer or bearings in the extruder motor?
Opublikowany : 21/08/2020 10:45 am
Topic starter
answered:
This is after using machine oil on both x axis rods.
Opublikowany : 21/08/2020 11:57 am
