vertical lines on y
Page 2 / 2
Mike
 Mike
(@mike-8)
Re: vertical lines on y
Is your belt properly aligned? For me it almost looks like the teeth of the belt are always scraping a bit on the wall of the idler. If that's it, then you should better straighten the belt and maybe apply some grease so the effect is not that strong.
Publié : 23/10/2018 9:22 pm
Mark
 Mark
(@mark-11)
RE: vertical lines on y
Hello, did you ever figure out these vertical lines issue? My prints are doing the exact same thing.
Posted by: @schichtenmacher
I need help....
i have vertical lines on my y axis and only on my y axis
left on the foto is y and right is x
what i allready have done:
- change belt ( stock and powrgrip gt3)
- change bearings (stock, cheap one and misumi)
- change printed parts
- Belt Status X 260 and Y 265
- test silent and normal mode
all make no different
just ordered new pulley, that the only thing i did not change
Slicer Prusa (latest) stock settings
Firmware latest
what could it be? because its only on the y axis
Publié : 14/05/2022 1:52 pm
Mark
 Mark
(@mark-11)
Hello, I'm having the exact same issue with my prints. I see vertical lines in my Y-axis side, however I also see them very slight in my X-axis. My belts are the correct tension, rods clean and lubricated. New nozzle, latest firmware, using dry PLA. It just seems too uniform to be a hardware issue, could it be a slicer issue? Or some other software issue I'm overlooking? Thanks
Publié : 14/05/2022 1:55 pm
Page 2 / 2
