Using Printrun 2.0.0rc7
maker_714
(@maker_714)
Hello, I have been using my MK3s for the past 6 weeks with good printing results.  Now I would like to use Printrun to avoid having to do the SD card shuffle.
I sliced the STL file with Prusa Slicer 2.2.0+ and uploaded to Printrun but received an "Unknown G code" and "K out of allowed range!" errors during the file processing.  I aborted the print and decided to transfer the gcode to SD card for printing.  I have attached the gcode file with this post.
This is the printout from the Printrun console:
Print started at: 19:08:23
NORMAL MODE: Percent done: 0; print time remaining in mins: 216
SILENT MODE: Percent done: 255; print time remaining in mins: -1
SILENT MODE: Percent done: 0; print time remaining in mins: 217
MMU not responding - DISABLED
tmc2130_home_enter(axes_mask=0x04)
tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x04
tmc2130_home_enter(axes_mask=0x01)
  0 step=45 mscnt= 728
tmc2130_goto_step 0 45 2 1000
tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x01
tmc2130_home_enter(axes_mask=0x02)
Unknown G code: $28 G21
LA10C: Linear Advance mode: 1.5
echo:Advance K=0.05
echo:Advance K=0.05
Warning: The print progress message might be too long to be displayed properly
Disconnected.
Apple-watch-charging-dock_0.2mm__white_PLA_MK3S_3h36m.gcode
Can I ignore these errors and print with Printrun regardless?  I did not want to find a failed print given the print is over 3 hrs in duration.
Thanks for your help.
Respondido : 17/11/2020 1:21 am
