Using a Prusa Mini Filament Sensor on a Mk3s
NickRno77
(@nickrno77)
I’m using a E3D Hemera extruder which doesn’t have a filament sensor, I trying to use a Prusa Mini Filament sensor. Trouble is when filament is loaded the switch is set to 0 so I need to toggle this on the Firmware. I could redesign the filament sensor housing but ideally I’d like to do this in FW
Can somewhere point where and what to change in the firmware.
Thanks
Attachment removed
Posted : 31/03/2021 4:33 pm
