Useful upgrades
Astroprinter
(@astroprinter)
Useful upgrades
I'll receive my MMU for the MK3 soon and in consequence will have to do some disassembly and maintenance on my printer. Since I am at it, I am wondering what printed parts upgrades would be useful to do. I'll get the new extruder fan parts anyway and the flexible sleeve, but there was also a suggestion for dented belt rollers for x and y axis and I can't find the size reference for those anymore.
Any other suggestions?
Thanks
Berthold
MK3
Veröffentlicht : 21/12/2018 7:30 pm
Re: Useful upgrades
https://www.ebay.co.uk/itm/GT2-Aluminium-Timing-Pulley-20-Tooth-Bore-3mm-For-3D-Printer-Width-6mm-Belt-10Pc/222652230306?hash=item33d71b6aa2:m:ma1oRR4DtyNyMQeA7ADLuFA
Veröffentlicht : 21/12/2018 8:01 pm
Astroprinter
(@astroprinter)
Re: Useful upgrades
Thanks Joan!
He does not send to Spain, but I found those on Amazon.es:
https://www.amazon.es/dp/B074DVWQLP/ref=sspa_dk_detail_0?psc=1
MK3
Veröffentlicht : 21/12/2018 8:22 pm
Astroprinter
(@astroprinter)
Re: Useful upgrades
Is it worthwhile to get IGUS linear bearings for the bed?
MK3
Veröffentlicht : 21/12/2018 8:26 pm
Re: Useful upgrades
I took mine off and replaced with lm8uu on wednesday and I won't use them on my prusa's again
started jamming after a short period of use
Joan adjustable X axis belt ends and adjustable y belt end might be good
Veröffentlicht : 21/12/2018 8:53 pm
Astroprinter
(@astroprinter)
Re: Useful upgrades
Are you referring to this?
https://www.thingiverse.com/thing:2846079
That seems like a lot of trouble and modification...
MK3
Veröffentlicht : 21/12/2018 9:44 pm
Re: Useful upgrades
that's one option
https://www.thingiverse.com/thing:2740715
is another option
Joan
Veröffentlicht : 22/12/2018 2:31 am
LA 3D Printer Repair
(@la-3d-printer-repair)
Mitglied
Re: Useful upgrades
Installing the R3 extruder - mainly for the textile sleeve - and giving your machine a thorough mechanical review to correct assembly errors is your best possible "upgrade".
Print yourself the new Einsy enclosure with the cable clamps!
is another option
Is not SCAD, Prusa "improvements" that don't include source code are evolutionary dead-ends for certain.
Also the current X-Motor end design has integrated post-assembly belt tensioning.
Veröffentlicht : 22/12/2018 8:32 am
Astroprinter
(@astroprinter)
Re: Useful upgrades
Hi again,
Just another quick question before jumping on exchanging the standard idlers for toothed ones.
What is the primary benefit for doing this modification and why doesn't Prusa supply those idlers in the first place? Is there any advantage to using idlers without teeth?
Thanks
Berthold
MK3
Veröffentlicht : 13/01/2019 1:52 pm
