Upgrading Hardware and Software for 1.75 filament
alefachinic
(@alefachinic)
Hello Community:
Well, I am Alejandro and I'm new in the Forums.
I built a Prusa I3 some years ago and then i forgot about it. The thing is that it works with 2.85 mm filament and i want to update the hardware and software to 1.75 mm filament. I'm from argentina and is very difficult and expensive so i'll try to minimize costs.
Which are the least things that I will need? Now I'll put some images to share what i think.
First the HotEnd (current):
Hotend Disassembled HotEnd Parts
Then is the internal Teflon that is also for 2.85 filament
Internal teflon Goes inside Hotend
Now the pictures of my Extruder:
Extruder 1 Extruder 2 Extruder 3
Questions?
Which is my extruder model?
Which hotends could i use?
Should I buy new extruder for 1.75 filament and also new hotend?
IM using old 12 Volts hardware, Is there an issue with this?
Thank you very much
Opublikowany : 12/05/2020 6:17 pm
alefachinic
(@alefachinic)
RE: Upgrading Hardware and Software for 1.75 filament
No one can help?
Opublikowany : 13/05/2020 7:21 pm
