Upgraded my machine to the latest firmware. It now gives ne a constant Thermal Anomaly Error!
BillR94
(@billr94)
I just updated the firmware to 3.13.2. The machine now constantly beeps with Thermal Anomaly error. The machine continues to print fine but the beeping is annoying as !@#$. Is there a fix for this? Please help, I'm going deaf! BTW, this is the stock hot end that came with the machine.
Thank you
Bill
This topic was modified 2 years temu by BillR94
Opublikowany : 22/01/2024 8:56 pm
Hello
(@hello)
RE: Upgraded my machine to the latest firmware. It now gives ne a constant Thermal Anomaly Error!
Posted by: @billr94
Thank you
Bill
There is a Chace that the thermistor is on the way out so I highly recommend you get a replacement. But if you need to print for now you can flash 3.11 firmware which gets rid of this.
WARNING DO THIS AT YOUR OWN RISK.
this feature was put in the firmware for a reason and that's to stop melting hotends. It's not at all recommended to ignore it flashing 3.11 is just a work around.
Opublikowany : 22/01/2024 10:43 pm
BillR94
(@billr94)
I just put a new Thermister and heater in a couple of months ago purchased from the Prusa website. I might have gotten a bad one?????
Opublikowany : 23/01/2024 3:02 am
Hello
(@hello)
Posted by: @billr94
There is a chance it could be bad. I'd contact prusa via live chat as it's still under warranty. Don't let theme tell you to ignore it.
Opublikowany : 23/01/2024 3:31 am
BillR94
(@billr94)
ok...I'll give it a shot. Thank you
Opublikowany : 23/01/2024 3:34 am
