upgrade message
jmmprog
(@jmmprog)
upgrade message
Hi, my printer work perfecly and i receive a message on screen please upgrade with a new version....my problem is i dont want upgrade because my printer work very good with this version, my question is how i remove this message?
thank you
Opublikowany : 29/05/2019 8:00 pm
RE: upgrade message
Go into the Slic3r printer settings and change the line below. You'll need to save as a new profile - then remember to use the new profile ... Plicer should remember the last "state" and it should be pretty easy ...
In the Printer Settings tab, in Custom G-code: Change  Start G-code from
M115 U3.7.1 ; tell printer latest fw version
to
M115 U3.0.0 ; tell printer latest fw version
This post was modified 7 years temu 2 times by --
Opublikowany : 29/05/2019 8:04 pm
jmmprog
(@jmmprog)
RE: upgrade message
Thank you very much for this information 🙂
Opublikowany : 30/05/2019 1:42 pm
