Unsmooth starting points
Schehlein
(@schehlein)
Hey there.
Since a few weeks I have an issue: Whenever the printer starts to print a new layer or a new line, a "dot" appears. this causes the surface to be unclean (see picture and video). Is there anybody else with the same problem or does anybody have a solution?
Prusa I3 MK3S, Prusa Slicer 2.1.0+, newest printer firmware
Thanks in advance for your aid!
Bernd
https://forum.prusa3d.com/wp-content/uploads/2019/10/IMG_0817.mp4
Respondido : 28/10/2019 12:58 pm
RE: Unsmooth starting points
Those are seams.  Generally, you set seam position to somewhere they won't be seen. Rear, or aligned work well.   Reducing distortion around a seam requires playing with kfactor calibration, retraction (every filament behaves differently and the same filament behaves differently at every temperature), z-hop, jerk & acceleration settings, layer height, and perimeter print speed.  There isn't a setting that fits all cases. At least, not one I've seen.
Respondido : 29/10/2019 12:00 am
