Units in Slic3r
I use Shapr3D on my iPad Pro to create my projects. I save it as an stl file. Usually, things go well, but Lately, when I create a project that is 10cm tall, when I import it into Slic3r, it shows up as 10mm tall. Is there anything I need to do to make sure Slic3r keeps the same units of a project I create ?
Publié : 09/02/2019 9:22 pm
Re: Units in Slic3r
Slic3r has a "Scale" button top dead center. But if you want to avoid having to use the Scale button, do your designing in millimeters.
Publié : 09/02/2019 9:46 pm
