Uneven Walls
Prusa Bantha
(@prusa-bantha)
Uneven Walls
I'm having problems with tall straight walls. There's some unwanted ghosting and artifacts on the outside and inside of the walls.
I've attached photos of the print vs. the sliced object.
Any idea on how to fix this?
Print
Postato : 15/04/2021 7:06 am
RE: Uneven Walls
You need more perimeters, at least three for a smooth wall.  If the wall is less than about 2.25mm thick a 0.4mm nozzle doesn't have enough room to align the outer perimeters correctly and still keep it connected to the other side, the slicer has to make compromises.
Postato : 15/04/2021 10:23 am
Swiss_Cheese
(@swiss_cheese)
RE: Uneven Walls
@prusa-bantha
Can you provide a Zipped up .3mf project file? it will allow us to look at the settings your using and how they are applied to the model.
you can post the zipped up project file here by selecting the "Add Media" button above the texting area then dragging & dropping your zipped up project file into the resulting window.
Regards,
Swiss_Cheese
The Filament Whisperer
Postato : 16/04/2021 7:30 am
