Uneven Top Surface Issue
gmurad
(@gmurad)
Hey everyone,
I encountered an issue that I have now put significant amount of time and experimentation and can not fix. I have documented the issue here:
https://www.reddit.com/r/3Dprinting/comments/gs64fd/uneven_lines_on_the_top_layer/
Does anyone have suggestions of things to try? I feel like I exhausted my options yet I have not identified and fixed the issue.
Thanks!
Napsal : 29/05/2020 4:10 pm
RE: Uneven Top Surface Issue
A bent heatbreak could be the problem.
the extruder may  create less squish in one direction of travel. because of the bent heatbreak...
another option, may be reducing the flow rate .
default flow rate in Prusa SLicer, is 95%, try 90%
or try Octogram spiral, or Hilbert curve to use surface texture to your advantage!
Napsal : 29/05/2020 8:07 pm
gmurad
(@gmurad)
@joantabb
It could coincide with when I changed the nozzle. I used a large tool so I probably had too much torque. How can I test that theory? Is the only way to take apart the entire hotend/extruder? Also, if that's the problem can I straighten it somehow? I have access to a new heatbreak at a reasonable price if it's that.
Napsal : 29/05/2020 8:15 pm
gmurad
(@gmurad)
An update on this is that I tried to straighten the nozzle by forcing the heatblock back to a level position with pliers and reprinted. Exact same bad quality came out. I tried to tweak it a bit more and the heat break snapped.
After that I ordered a new titanium V6 heat break, waited for shipping and finally installed it along with a new PTFE tube and new bearings on X and Z axes. After all of that I reprinted the model and it came out identically bad to before I broke the heatbreak. I'm back where I began.
If anyone has suggestions please advise.
Napsal : 02/06/2020 2:41 pm
@gmurad
Hi,  the Heatbreak is a very thin tube , it is likely that the stainless steel would fracture if you try to straigten it,  so I would buy a new heatbreak, and if I didn't already have them in stock I would buy a heater and thermistor, because there is a good chance that you will damage them whilst changing the heatbreak...
I also usually have heatsink compound for the threads inside the heatsink, and Coppa Slip, for the threads inside the heatblock...
https://help.prusa3d.com/en/article/hotend-disassembly-heatbreak-stuck-in-the-heatsink_112677
Napsal : 02/06/2020 6:43 pm
Have you tried reducing the flow rate on the print, to say 90% or perhaps 85% (the default is 95% in Prusa Slicer)
Napsal : 02/06/2020 6:48 pm
gmurad
(@gmurad)
@joantabb
The flow is calibrated for the printer using a 2 walled cube with on infill, no top and no bottom layers. I have line width set to 0.45mm and I get an average really close to 0.9mm so I don't think there is a problem with the flow but I will try lowering it, that should make the lines less visible but I don't know if that's a solution.
I'm also attaching the model here that causes the problem in case someone wants to print it. Perhaps it's an issue with the model.
Napsal : 02/06/2020 7:02 pm
gmurad
(@gmurad)
@joantabb
Sorry I forgot to follow up here. I reduced the extrusion multiplier to a value bellow that which I arrived at after calibrating using a 2 wall hallowed cube method and this fixed most of the surface issue I was experiencing. I wonder why if I calibrate it for walls it "over-extrudes" the lines on the top layers.
Is there a setting to allow me to change the extrusion multiplier just for the very last top layer of the print? I think that would fix my issue.
Here is a picture after lowering the extrusion rate bellow the calibrated amount, the top surface looks much better, I can still see where lines meet by it's less visible:
This post was modified před 6 years by gmurad
Napsal : 06/06/2020 12:04 pm
You could edit the G code to insert
M221 S90 ; Reduce Flow Rate to 90%
at the layer height that you want the change to occur.
Napsal : 06/06/2020 6:01 pm
Peter M
(@peter-m)
If you cover the holes with 1 or 2 layers, then after printing cut the holes open.
The printer has then only 1 flat square, and you have a nice layer.
Napsal : 06/06/2020 9:18 pm
