Under Extrusion? Happening on 2x Mk3s+ Units
TheNore
(@thenore)
Contributor
Picture attached of the issue. This looks like under extrusion. I hear no "clicks" during the prints either.
Background
On both units I have:
-Fully disassembled the Extruders
-Re aligned the gears
-Replaced the PTFE Tube
-Cleaned/ColdPull the Heat break+Nozzle
-Cleaned the Heat block
-Cleaned Nozzle (Vanadium by Slice- Do they wear out? I have had for 2+ years)
-Re Printed fan shrouds (One was melted)
-Applied new thermal paste to heatsink/heatbreak + Cleaned Fan
-Factory Reset both of my MMU2S Units as well
One printer has been performing slightly better after the "clean up" but still exhibiting some of the same issues. I have not performed a PID calibration, that will be next. Are there any other suggestions?
Opublikowany : 13/12/2022 11:47 pm
TheNore
(@thenore)
Contributor
RE: Under Extrusion? Happening on 2x Mk3s+ Units
Picture:
Opublikowany : 13/12/2022 11:49 pm
Hello
(@hello)
Hi I had this exact same issue with my mk3s spent 7 hours with prusas chat they told me that it wasn't under extrusion if you do self test film all axis in slow motion I had problem where one axis would stutter.
Hope this helps please let me know
Opublikowany : 14/12/2022 2:55 am
TheNore
(@thenore)
Contributor
Ok thank you for the response - Was there any remedy to the stutter ?
Opublikowany : 14/12/2022 3:40 am
What is the filament?  Pitting like this is sometimes a symptom of damp filament.
Opublikowany : 14/12/2022 2:59 pm
Hello
(@hello)
Yes replaced einsy and all working fine
Opublikowany : 14/12/2022 5:43 pm
1 ludzie polubili
TheNore
(@thenore)
Contributor
it is a brand new roll of prusament ;/
I thought it could have been this - bit as soon as it pitted on prusament I made this post.
Opublikowany : 14/12/2022 11:10 pm
Hello
(@hello)
yeah i tried evrything and as soon as i replaced board it is all good
Opublikowany : 15/12/2022 3:13 am
Did you dry the filament before printing?
You cannot assume  new = dry  as although it was packed dry when made you have no idea how long it has been in store or how it was treated in transit.
Opublikowany : 15/12/2022 3:20 am
Netpackrat
(@netpackrat)
Posted by: @thenore
I had one of those and it strung really bad.  I had to pop it in the oven for a while to get it to print right.
https://www.printables.com/@Netpackrat/models
Opublikowany : 15/12/2022 4:59 am
TheNore
(@thenore)
Contributor
Hum ok. I will try to dry the filament before use, and post results.
Opublikowany : 15/12/2022 1:27 pm
