Turn off heated bed and thermistor
Henry
(@henry-6)
I am having problems with the bed thermistor. I have a new thermistor on order, but would like to use the printer in the mean time. I don't need a heated bed for PLA. I tried setting the filament temperature to 0 but still had a shutdown due to mintemp. Is it possable to turn off the mintemp bed and bed heater.
Opublikowany : 02/03/2019 1:13 am
tonylweil
(@tonylweil)
RE: Turn off heated bed and thermistor
Same problem! Any solutions?
Opublikowany : 07/04/2020 7:58 pm
Posted by: @henry-d3
You could temporarily bridge the thermistor with a 100k resistor. The firmware requires the current value of the resistance of the thermistor to determine the temperature from a table. Because the thermistors (nozzle and bed) tend to break, I would always have one or two spareparts ready. Adapting the firmware requires a good knowledge of the system.
Opublikowany : 08/04/2020 3:24 am
