trouble with the Calibrate XYZ function starts touches heated plate then errors out
TeamBlitzJaeger
(@teamblitzjaeger)
Hello, I have been in the process of building my printer and during calibration ran into this problem
[youtube] [/youtube]
I have leveled the bed, double checked the height of the sensor, made sure nothing is blocking the X and Y Axis and have asked other and they have drawn a blank on the problem. any and all help is appreciated
Respondido : 30/11/2018 7:38 am
Olef
 Olef
(@olef)
Re: trouble with the Calibrate XYZ function starts touches heated plate then errors out
Your extruder is assembled incorrectly from what I can see. The hotend is not in the right place - it is too low. It is a common error. This causes your Z height to be too short and thus fails the calibration.
See https://manual.prusa3d.com/Guide/5.+E-axis+assembly+(textile+sleeve)/822?lang=en for correct method. Pay close attention to step 17 on.
Good luck!
Respondido : 30/11/2018 7:51 am
TeamBlitzJaeger
(@teamblitzjaeger)
See https://manual.prusa3d.com/Guide/5.+E-a ... 22?lang=en for correct method. Pay close attention to step 17 on.
Good luck!
I feel like an idiot thanks for the help
Respondido : 30/11/2018 10:09 am
