To stop or continue assembly - missing LED cover
Pursuit
(@pursuit)
Utenti
I’m getting a replacement shipped, but it will be a week+ so I want to check opinions.
how hard would it be to install that later in the process? I assume the question is the same as “how hard is it to replace the heatbed LED”
thanks!
Postato : 21/11/2025 10:04 pm
Robin_13
(@robin_13)
RE: To stop or continue assembly - missing LED cover
Are you talking about the two piece cover at the heat bed?  If so, it can be replaced in a few minutes.  You don't need it to run the printer other than some strain relief on the power cables.
Postato : 01/12/2025 6:43 pm
