'Time to print' in gcode file name?
I just noticed this. Seems only the last day or two.
New to Prusa Slicer?
Can it be disabled?
Mk3 - 1X
Mk3S - 2X
2021 Hyundai Palisade
Wife - 1X
Napsal : 05/06/2019 2:18 am
RE: 'Time to print' in gcode file name?
Look at output options under Print Settings.
Napsal : 05/06/2019 2:25 am
The name has got a little verbose for the line length of the printer display. I can edit the string in the settings so I just have the filename and layer height. How do I make it default to that?
Retired doc, should have been an engineer.
Napsal : 07/06/2019 2:28 am
You must save a "new" print profile .. once you make the change, edit the name in the upper left and click the [disk] icon to save the new profile.
Napsal : 07/06/2019 4:06 am
