        Thermistor Help!!
I have a Mk3S printer that I was happy with, until it blobbed the hotend completely. It was so bad that I had to order another hotend. I ordered everything from E3D and installed it. It seems as though the thermistor does not measure the temperature correctly, since when I try to calibrate the first layer it seems as though the nozzle is not getting hot enough, even though the thermistor reads 215.
Please help
                            Veröffentlicht : 04/06/2019 12:45 pm
                    RE: Thermistor Help!!
Did you buy a V6 with the PT100? If so, that's the wrong one and isn't directly compatible with the EINSY.
                            Veröffentlicht : 04/06/2019 10:40 pm
