Thermistor acting strange
Hi everyone,
Since last weer my thermistor is acting strange. It just measures from room temp till about 45C and the measurements are not correct because I burned my hand on the heater block when it said 45C.
What did I do to troubleshoot:
-I checked with two different original Prusa thermistors and they both act the same.
-Measured the thermistor resistance of both thermistors, they were correct.
-Measured the pins that the connectors were connected to (measured 4.7k Ohm).
Would it be possible to change the firmware so I can use another pins for the thermistor, or do you guys/girls think that the board is fried?
I just find it very strange that it does measure something..
With kind regards.
Veröffentlicht : 12/04/2021 12:11 pm
