Thermal runaway error
krazydinger
(@krazydinger)
Hey guys! I bought my Prusa I3 almost 2 years ago. I've never been able to get a print to start, I run into a Error:Heating failed, system stopped! Heater_ID: bed
I replaced the thermistor and the heating bed, along with multiple changes to the firmware before giving up on it.
I'm ready to tackle this printer and get it working. I'm starting over again, and I'm desperately looking for direction!
Respondido : 12/10/2020 3:09 am
RE: Thermal runaway error
Posted by: @krazydinger
Hello and welcome to the Prusaforum!
I would check if the power supply delivers a constant voltage (24V). It is also important that the current-carrying elements are clean and free of corrosion. (well fitted plug and screw connections).
Respondido : 12/10/2020 8:47 pm
Eddie9195
(@eddie9195)
Check to make sure that all of the wire connections are tight.
Also check the wires for continuity between the bed and the board.
Respondido : 14/10/2020 7:27 pm
Area51
(@area51)
Miembro
... and the fuses in the main board.
Respondido : 15/10/2020 12:44 am
