Thermal Anomaly msg during printing
Nimitz
(@nimitz)
3.5 hrs into a 4.5 hr print I started to get a Thermal Anomaly’ msg in all caps plus a continual beeping . The print continued until complete but something isn’t right? Ideas?
Opublikowany : 24/06/2023 1:51 am
mkscho63
(@mkscho63)
RE: Thermal Anomaly msg during printing
I get the same or similar issue. I will sometimes get failures sporadically during my prints but my last print failed at 9 hours into a 30 hour print and refused to proceed until I finally had to call it quits (spent an hour attempting to proceed, but every time it started up it would move into position then get the Thermal Anomaly message and go into a hold with temps set at 0 again). The issue has started occurring since I updated firmware to 3.12.2. Did you update firmware recently as well potentially?
Opublikowany : 24/06/2023 2:43 am
Hello
(@hello)
100s of posts on here about it. It is a thing in the firmware that doesn't work right go to firmware 3.11 and problem solved
Opublikowany : 24/06/2023 6:13 am
Nimitz
(@nimitz)
Yes!  I recently updated and that’s when this issue started …
Opublikowany : 24/06/2023 12:44 pm
Nimitz
(@nimitz)
Copy, thx!  My search skills obviously suck as the first thing I did was search ‘thermal anomaly’ and nothing came up … 🙁
Opublikowany : 24/06/2023 12:46 pm
Hello
(@hello)
 I searched thermal anomaly and got 5 pages of results any way now to know
Opublikowany : 24/06/2023 8:06 pm
