Thermal Anomaly Errors After Power Supply Swap – Need Help!
E Shively
(@e-shively)
Hey everyone,
I recently swapped out my stock power supply for a Meanwell LRS350 after the original one burned out during a PETG print. Everything is hooked up properly, but I’m running into a new issue.
When I try to preheat the printer to remove the PETG from the previous overheat, I keep getting thermal anomaly errors. I’ve tried clearing the air and even went through the calibration process to see if that would help, but it just ends up saying "Stop" and "Print Aborted."
Has anyone experienced something like this? Any advice on how I can solve this would be greatly appreciated.
Thanks in advance!
Publié : 04/09/2024 10:00 pm
Eef
 Eef
(@eef)
RE: Thermal Anomaly Errors After Power Supply Swap – Need Help!
Check the voltage with a multimeter.
Is it 24 Volt? And when you measure while starting up, do you see the voltage dropping?
Publié : 05/09/2024 5:03 am
E Shively
(@e-shively)
Will do and let you know what I find this weekend, Thank you for taking that time to reply 🙂
Publié : 05/09/2024 11:50 pm
E Shively
(@e-shively)
I checked all my connections by unhooking and re hooking them up and gave it a go. Started right up and is good to go so far!
Thank you
Publié : 15/09/2024 6:54 pm
