The filament sensor response is poor, disable it?
Gerd Lobmeyer
(@gerd-lobmeyer)
Hi, I am running my mk3 on version 3.4.0 an I get the error "The filament sensor response is poor, disable it?" if I activate the sensor. I read in the topic for the version 3.4.1 that this is a bug and will fixed in the version 3.4.1? Or it is only deactivated in 3.4.1 until you will find a solution?
Regards,
Gerd
Opublikowany : 30/09/2018 6:13 pm
Pathogen
(@pathogen)
Re: The filament sensor response is poor, disable it?
It is unclear where this will lead, they have built this in to kludge around whatever the problem is, and work on the problem itself continues. The kludge is for the rewritten filament sensor function. Also there may some mystery around one of at least one of the issues
<snip>, who really knows whats going on but a lot of people including myself are quite happy with the final 33 firmware.
EDIT: correct link: https://github.com/prusa3d/Prusa-Firmware/issues/1186#issuecomment-425326128
Opublikowany : 01/10/2018 12:50 am
Gerd Lobmeyer
(@gerd-lobmeyer)
Thanks Pathogen, I will try out the 33 final. For me the sensor is one of the big points to upgrade from a MK2S to MK3.
Regards
Gerd
Opublikowany : 01/10/2018 8:43 am
