Temperature fluctuations
harsh.b
(@harsh-b)
Hey,
I got a Prusa i3 Mk3 2 month ago. It has been working fine.
But a couple of days ago the temperature started fluctuating.
It fluctuates only while printing and not loading filament. We are using Slic3r Pursa Edition to slice the model.
Reading online I found solution for tuning PID (which i did) and check cable connection (which i checked).
Nothing out of above has worked so for.
Regards.
Napsal : 10/10/2018 7:06 pm
Texy
 Texy
(@texy)
Re: Temperature fluctuations
Double check screws are tight on the einsy board that feed the PSU. Also check the extruder heater and extruder thermistor connectors to einsy.
Texy
Napsal : 12/10/2018 8:40 am
