Support blocker problem 1.42.0
Kraut55
(@kraut55)
I am trying to print a batman with outstretched arms and want to use the support blocker to prevent any support at the body.
When I extend the original box size (25x25x25) it also extends below the heatbed. When I try to pull it up to the surface it vanishes into space.
Opublikowany : 10/04/2019 2:17 pm
Re: Support blocker problem 1.42.0
Hi Hans,
I don't think there is any problem with the box being below the build plate
however if you do want to correct that, then use the scale tool to enlarge the box, then use the move tool to move the box upward
trying to use the scale tool to move upwards results in the box having on thickness
Opublikowany : 10/04/2019 2:36 pm
Kraut55
(@kraut55)
Hi Joan,
thank you for your advice. Everything works just fine now.
Regards
Hans
Opublikowany : 11/04/2019 1:29 pm
