Stuck extruder after fillament runout and change
Mike Daneman
(@mike-daneman)
I was trying to maximize my filament usage and printed some simple parts using a roll that was nearly out and, when it ran-out and the printer paused due to filament sensor, I feed a new roll of filament into it.  When the filament sensor triggered, I pushed the knob to unload filament, which, of course, didn't unload because there was nothign left to unload.  I then fed the new filament and it extruded some through the nozzle and went back to printing.  This is the first time I did this and initiallay thought it worked, but then I walked away from the printer shortly after the filament change and came back to see that the extruder jammed and it completed the print "printing in the air".  I got the extruder unjammed, but was wondering if I did somethign wrong in how I fed the new filament.
The filament that ran out had a bend at the end where it was attached to roll and I wonder if that's what made it jam.  Do you guys have experience with filament running out and how to best deal with it?  Should I generally avoid letting this happen in the future or should I make sure the last bent piece of filament is cut off?  Any advice?
Thanks.
Publié : 23/10/2019 10:58 pm
1 personnes ont aimé
Olef
 Olef
(@olef)
RE: Stuck extruder after fillament runout and change
Make sure the bent piece is cut off or it will not feed as you found. When the sensor triggers for end of filament it should unload itself ready for you to remove it.
Publié : 23/10/2019 11:30 pm
When the sensor triggers, there should be filament in the gears (the sensor is well above the gears).  Usually, the filament is "bent" at the end where it attaches to the spool; this bend gets caught in the sensor area and won't unload, and a disassembly of the sensor ball is required.  Sometimes removing the cover is enough, and with dexterous use of tweezers you can fish out the bad end; otherwise, you can open the idler door, cut the filament at the gear, pull the upper fragment down and out, and heat the extruder and pull the lower fragment up and out (pliers help that last pull).
Publié : 24/10/2019 4:06 am
Jim
 Jim
(@jim-9)
@tim-m30
I've noticed the same thing happening after the 'bent' end disappears beneath the sensor cover and jams when the 'unloading' process starts as you stated.
Do you (or anyone) know of a method or 'trick' to resolve this?
Waiting till the end of a spool of filament just to catch the end from going in reminders me of the high maintenance and attention my MK2 requires. One of the reasons I purchased an MK3S was for the filament sensor but if I have to remove a jam each time it is a bit frustrating.
Any thoughts, comments, or suggestions would be appreciated. Thank you.
Jim
Publié : 02/01/2020 3:31 am
bgoner
(@bgoner)
I'm almost in the same boat. Managed to get it out without cutting it in half so I didn't get an extruder jam. But then those noises appeared. Do some of you have them?
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/squicking-noise-after-empty-filament-error/
Is there an easy way to clean the ball housing without disassembling everything?
Ce message a été modifié il y a 6 years par bgoner
Publié : 03/01/2020 12:50 pm
bgoner
(@bgoner)
We should definitely ask Prusa to include this in the manual, no matter how much they don't want it: "If the end of the filament is bent the filament fail system won't be able to push the end of the filament back and it will jam. If you are close to the end of the spool cut the bent end if you want the feature to work."
Or something similar.
They definitely know about this. Maybe they don't want to mention it cause its admitting that the feature does not work as advertised.
p.s. - fixed my squeaky noise with compressed air in the filament hole by holding the filament sensor lever open as much as possible.
Publié : 04/01/2020 8:14 pm
Kent Prints
(@kent-prints)
The manual has a procedure that work when your problem happened to me. I had to take some extra steps, but this is a good place to start:
None of the filament is going through the nozzle
If none of the filament is going through, then most likely, your hotend got clogged. In order to fully clear it, please follow these instructions:
1. Heat up the nozzle to 250 °C for PLA or 270°C for ABS jams.
2. Wait 3-5 minutes and then go to LCD Menu - Load filament. If you cleared the clog and the filament went through, simply lower the temperature to normal and re-do load filament again.
3. If the filament loads successfully, you can resume printing.
In addition to the above, I pulled the end of the filament (visible when opening the idler door) out very "carefully". A heat gun, dutifully aimed, may have helped, but I went the he-man route (brute force).
Publié : 17/09/2020 6:43 pm
2 personnes ont aimé
ETAgrow
(@etagrow)
This is that one thing that drives me crazy about my MK3S. Why the f**** do we need to unload the filament when a spool is finished? I mean ok, stop the print when the sensor triggers, heat up the extruder (so far so logical) but WHY do we need to unload, when the firmware could just turn on extrusion as soon as you insert the new filament, load the new one and print as if nothing ever happened? My extruder gets jammed every single time this happens (and that is about once per week). My best solution was just hoping i realize when the filament nearly runs out and than wait 20 minutes until the last bit is in there and try to push the new filament in seamlessly so that the sensor never triggers. Which is not only very hard to do but also works only every third time. Mostly it is opening the idler, fiddling with the filament for 10 minutes until the upper part is removed and than watch the extruder getting haywire when it thinks it is empty and tries to insert the new filament at full speed while still loaded.
Fix this PLEASE guys! Skip the unloading part and just turn on the extruder as soon as new filament is sensed. Problem solved for all of us!
Publié : 05/11/2021 7:55 pm
