structur3d paste 3D printing with MK3
franco.o
(@franco-o)
hello everybody
I just bought a discovery from structur3d, it is an addon for any FDM printer where you use the motion system of the printer and add an external nozzle that is attached to the extruder body and you can print paste base materials, like chocolate, silicone, and others.
anyway, the thing is that you obviously need to connect the extruder motor of the addon where the extruder is connected in the Rambo.
my question is, is there any way to be able to connect another motor to the Rambo? as I saw that in the slic3r PE you can add multiple extruders I thought that maybe it would be possible to add by Arduino or raspberry or anything else another connection for a motor. that way I would choose what extruder use in the slic3r and I would not need to be disconnecting one or the other in the Rambo or at least a switch that allows me to switch the connection between one and another easily from outside the case?
any help would be appreciated :D, and also if there is any other user using this system or something similar I am interested in the subject.
Respondido : 16/04/2019 4:07 pm
