Strange Temperature Setting
Illmilliner
(@illmilliner)
Hi friends,
Recently, I have a lot of failed prints at the exact same height regardless of the size and volume of the object. I stopped my latest print I saw the the nozzle temperature was 170/170. My filament setting was definitely not 170. I remember that I used someone else's automatic temperature tower gcode that had the function int(layer_z / 8). Could that line of code some how stayed with the slicer or the firmware itself. I have attached the amf of the latest failure that some how set the temperature to 170 mid print. Please help me out. Thank you so very much in advance.
This topic was modified před 5 years by Illmilliner
Napsal : 24/11/2021 8:51 pm
Illmilliner
(@illmilliner)
RE: Strange Temperature Setting
Can't seem to attach the file so I put it on Google Drive instead
https://drive.google.com/file/d/1-pJfG-4q2mGnOOHO2UQZ3BQlTgBpHAjM/view?usp=sharing
https://drive.google.com/file/d/1HGRpoIDdRPQg9vMuu44BcYf_0Q1-OFQ1/view?usp=sharing
Napsal : 24/11/2021 9:00 pm
Dan Rogers
(@dan-rogers)
To attach files you have to zip them
If you take the sliced .3mf file, right click it, send to ... compressed folder... remember the name of that folder - it is a zip file.  You can upload that zip file with the "choose file" button underneath of the text window where you type.
Napsal : 25/11/2021 5:24 am
1 lidem se líbí
From Prusaslicer, go to the File menu and use the Save Project as.. command to save a .3mf file. It will contain ALL your settings so we can see it. Then ZIP it, sometimes called Compress, or you will not be able to upload it.
Napsal : 25/11/2021 3:16 pm
